Locked Hog 4 Console
A Hog 4 console is locked and shows the following pin code screen:
The console is locked
This can be caused by logging into a showfile and pressing [SETUP] (Lock)
- Try the Default pin code "1234"
- Turn off the console, turn on the console
Note: The console lock screen is intended to be a deterrent when an operator is away from the console
