Midi timecode is not recognized by Hog 4
Midi timecode is coming into the desk, but it is not being recognized.
The timecode widget is not assigned in the DP 8000 settings
  1. Open the Network window
    1. [ Setup ] -> (Network)
  2. Tap on DP 8000 and hit Settings
  3. Go to Timecode Widgets
  4. Activate an input by hitting the blue plus sign
  5. Select the proper widget from the drop down menu
  6. Hit OK
  7. Make the list's timecode source be the DP 8000
    1. Open the List Options
    2. Change the Source in the Cuelist tab
  8. If still not recognizing timecode, log off the show and launch again
