Numbers on PC keyboard in Hog 4 PC choose the fader
In Hog 4 PC, using a keyboard to type 0 through 9, the function of Hog 4 PC is choosing the master or the fader instead of putting the number on the command line.
Alt is being held down either on the keyboard or in the software. Usually, this is caused by using the ALT + TAB shortcut.
Hitting ALT on the keyboard should release ALT from being held down.
