What do all the buttons at the top of an Editor window do?
Question
What are all the buttons at the top of an Editor window (like the Programmer, Cue Edit, etc.)?Toolbar.JPG
The top bar of buttons are different data views
  • Value: displays the values for each parameter in the editor
  • Fade: displays the fade times for each parameter in the editor
  • Delay: displays the fade times for each parameter in the editor
  • Path: displays the fade in and out paths for each parameter in the editor
  • Size: displays the size of any effects running on any of the parameters in the editor
  • Rate: displays the rate of any effects running on any of the parameters in the editor
  • Beats: displays the beats for any effects running on any of the parameters in the editor
  • Offset: displays the offset of any effects running on any of the parameters in the editor
  • Length: displays the length setting of any effects running on any of the parameters in the editor
  • Table: displays the effect shape of any effects running on any of the parameters in the editor
  • NShots: displays the number of times an effect will repeat before stopping of any effects running on any of the parameters in the editor
  • Bounce: displays whether the effect bounce setting is enabled of off on any effects running on any of the parameters in the editor
  • Direction: displays the direction of any effects running on any of the parameters in the editor
  • Begin: displays one of the limits that an effect will encounter on one end of an effect running on any of the parameters in the editor
  • End: displays the other limit that an effect will encounter on one end of an effect running on any of the parameters in the editor
  • Start: displays the starting value for any parameters with an applied effect running on any of the parameters in the editor
  • Sync: displays the sync setting of any effects running on any of the parameters in the editor
  • Effect Fade: displays the fade time of effects running on any of the parameters in the editor
  • Effect Delay: displays the delay time of effects running on any of the parameters in the editor
  • Effect Path: displays the fade in and out paths of any effects running on any of the parameters in the editor
  • Show Palettes: toggle whether parameters receiving data from a palette display the palette name, or data hard values
  • Fade Changes: when selected, live changes will fade in using the fade times in User Preferences, rather than snap in
  • Compact: shows a compact view of the editor
​​​​​​​Programmer Compact.JPG​​​​​​​​​​​​​​
