AAS (Analog Address System) - Troubleshooting
This walks through common Analog Address System (AAS) problems and ways to resolve them.
LED activity
  • Do stations have LED activity? (Will switch between Green and Yellow when pressed)
  • Is the CR7 green LED on solid on the AAS CPU? (this is the station voltage indicator, which should be between 10.4 - 12.0 VDC)
Station voltage
  • Do stations have 10.4 - 12V DC?
    • Factory setting is 10.4V, but it can be increased to 12V if fader levels are not reaching full due to long wire runs to stations.
LCD screen activity
  • Is there any information on the LCD screen? In monitor mode?
Fuses
Software Setup
  • Is console mode set correctly?
  • Is patch correct?
Red Switches
Does anything change when you toggle them?
[Reset\Normal] Resets AAS processor
[Term on\Term off] Terminates DMX input
[Bypass\Normal] Bypasses DMX input
Gray Switches
  • To Clear All (patch 1 to 1, Fade Time = 00, Console = Disable)
    • While continuing to hold down ENTER, move SW1 to Reset then back to Normal. Do not release ENTER until the screen says, “OK, release” (Clear All” is shown before “Ok, release”)
  • To reset AAS to Default patching (does not change Fade Time or Console settings):
    • While continuing to hold down DIMMER UP, move SW1 to Reset then back to Normal. Do not release DIMMER UP until the screen says, “Ok, release” (“Build Defaultis shown before “Ok, release”)
