Network Error 10013 when trying to ping ETCNomad Eos family Consoles
When attempting to ping a console from a computer in a multi-console system, a message response says Network error 10013.
Error 10013 indicates that a needed socket connection is being denied and that a port is blocked and/or unreachable.
Most likely Eos is being blocked by firewalls on your computer. It is also possible that any Anti-virus/network protection software could be blocking communication. Check your firewall settings on the computer to see if you are allowing access to the Eos software.
