Revisions of Selador Switched Linear Control Card
Rev 1
  • Distinguishing Feature is the soldered power lead.
  • Says "Rev2" on board.
  • No fan connector.
  • Must be calibrated at ETC (no auto-calibrate feature).
  • Typically only used to control K2 LEDs.
Rev 2
  • Distinguishing Feature is the daughter board on standoffs over the main control card.  This daughter card added fan control functionality.
  • Typically used to drive Rebel LED (Paletta, Lustr) but also K2 LED (Vivid)
Rev 3
  • Overall layout similar to Rev1&2, but has header for power input rather than soldered power lead.
  • Has a fan connector on the control card.
  • Has auto-calibrate feature which calibrates the control of the LED's.
    • To calibrate, hold down address buttons Up and Down until fixture enters "Cal" (calibrate) mode and calibrates each color individually (See article: How to Calibrate a Selador Fixture).
  • Rev3 is the terminal version of Selador control card.  PN 7400B5615.
  • Only used to control Rebel LED's but can be used to control K2 LED's using software version v1.08.
