All Gateway Software Versions
Description
The table below lists every version of gateway software (sometimes called firmware) and its corresponding release date by gateway product.
You can click the release date to download that version's release note.
Related Links
Filter:
Net3 and Response DMX/RDM Gateways
Version Release Date Key Enhancements Supported Hardware Software Download
7.1.0.9.0.5 October 31, 2019
Improvements to RDM implementation and optimizations to the gateway firmware
UpdaterAtor
7.0.1.9.0.17 November 30, 2017
Optimization for updating older versions of gateways and fixes existing issues
UpdaterAtor
7.0.0.9.0.11 March 30, 2017
Adds support for additional RDM transactions (ACK_TIMER) which support RDM products including the ETC ColorSource Relay. The software is migrated to a newer version of the underlying operating system and is improved through the resolution of software defects. This release also adds support for the Response DALI Gateway.
This version and subsequent ones remove support for "Switch to Net2 Mode"
UpdaterAtor
6.0.1.9.0.4 July 17, 2014
Fixes a vulnerability in the firmware update process for the Net3 Only varieties of ETC’s DMX/RDM gateway. When any version of firmware below 6.0.1 is loaded into ETC's gateways with Net3 only hardware, there was a small risk that the gateway would lose bootloader and require return to the factory for service.
This is the last version that supports the "Switch to Net2 Mode" on Gateways that can run in Net2 Mode
UpdaterAtor
6.0.0.9.0.2 April 24, 2014
Support for ETC Net3 DMX/RDM One Port Gateway
Not Available
5.1.1.9.0.18 January 16, 2014
Support for larger number of RDM messages in the RDM queue, removal of RDM Standby functionality, and bug fixes
  • Net3 Two and Four Port Gateways
UpdaterAtor
5.1.0.9.0.16 July 10, 2012
Dimmer Doubling Support, S4 LED and Desire software update port mode, and universe on the gateway displayed in place of port number.
UpdaterAtor
5.0.0.9.0.4 June 15, 2011
Adds support for a hardware component change in the Net3 Two Port and Four Port Gateways.
This version does not include an image for ETCNet2 devices - it should not be installed in devices running ETCNet2
UpdaterAtor
4.3.2.9.0.2 August 22, 2013 Bug Fixes UpdaterAtor
4.3.1.9.0.2 October 18, 2012 Adds configuration from Gateway Configuration Editor (GCE) and corrects defect in bootloader TFTP which could cause gateway to start an endless update cycle UpdaterAtor
4.3.0.9.0.16 July 17, 2012 Added configuration from Gateway Configuration Editor Not Available
4.1.0.9.0.15 June 24, 2010 Adds support for receiving both draft and ratified sACN and sends in ratified sACN. UpdaterAtor
4.0.3.9.0.31 May 11, 2007 Added DHCP support for Net3 Four Port Gateway in Net2 mode only
  • Net3 Four Port Gateway
Not Available
4.0.1.9.0.15 June 24, 2010 Adds support for receiving both draft and ratified sACN but continues to send in draft sACN for backwards compatibility UpdaterAtor
4.0.0.9.0.17 June 30, 2006 Initial release of Net3 Four Port Gateway in Net2 mode only
Not Available
4.0.0.9.0.10 July 23, 2008 Initial release of the Net3 One Port Gateway UpdaterAtor
3.1.0.9.0.4 June 24, 2010 Flexible Output Patch and add support for ratified Streaming ACN
UpdaterAtor
3.0.0.9.0.19 April 29, 2010 Receives both draft and ratified Streaming ACN but defaults to sending draft sACN (for compatibility in existing systems which have not yet updated)
UpdaterAtor
2.0.0.9.0.14 April 16, 2009 Adds support for RDM and bug fixes
UpdaterAtor
1.0.0.9.0.83 March 6, 2008 Initial Release of ACN support of Net3 Two and Four Port Gateways
Not Available
Net3 Show Control Gateway
Version Release Date Key Enhancements Software Download
1.0.5.9.0.2 February 21, 2013 Bug Fixes UpdaterAtor
1.0.4.9.0.12 September 20, 2011 Bug Fixes UpdaterAtor
1.0.3.9.0.74 April 29, 2010 Bug Fixes UpdaterAtor
1.0.1.9.0.66 October 9, 2008 Bug Fixes including critical lockup in version 1.0.0 UpdaterAtor
1.0.0.9.0.40 April 10, 2008 Initial Release Not Available
Net3 I/O Gateway
1.0.0.9.0.64 October 9, 2008 Initial Release UpdaterAtor
Response 0-10V Gateway
3.0.0.9 October 21, 2019 Adds discover and configurablity from Concert including custom curve configuration UpdaterAtor
2.0.0.9.0.6 September 22, 2016 Adds ability to patch 0-10V outputs within an sACN or DMX universe UpdaterAtor
1.1.0.9.0.3 February 4, 2016 Corrected defect in interface between main processor and external memory chip UpdaterAtor
1.0.0.9.0.12 September 17, 2015 Initial Release UpdaterAtor
1.0.0.9.0.23 April 16, 2017 Initial Release UpdaterAtor
Response MIDI Gateway
2.3.0.8 July 30, 2024 Performance improvements UpdaterAtor
2.2.1.8 April 20, 2022 Resolves an issue with external security tools UpdaterAtor
2.2.0.5
January 20, 2022
Provides support for the Eos v3.1.0 software release.
UpdaterAtor
2.1.1.12 March 11, 2021 Maintenance Update adds support for MIDI Notes UpdaterAtor
2.1.0.10 February 6, 2020 Maintenance update resolved MIDI output from ACN UpdaterAtor
1.0.0.9.0.16 May 10, 2018 Initial Release UpdaterAtor
Response Analog IO Gateway
2.0.0.23 March 15, 2024 Bug fixes UpdaterAtor
1.0.0.10 November 8, 2018 Initial Release UpdaterAtor
Response SMPTE Gateway
2.3.0.8 July 30, 2024 Adds new option for specifying expected timecode format and performance improvements UpdaterAtor
2.2.0.5
January 20, 2022
UpdaterAtor
2.1.1.12 March 11, 2021 Decreases SMPTE acquisition time and connection time to Eos Family consoles UpdaterAtor
2.1.0.10 February 6, 2020 Maintenance update UpdaterAtor
2.0.0.4 September 12, 2019 Initial Release UpdaterAtor
Response Serial Gateway
2.2.1.8 April 20, 2022 Resolves an issue with external security tools and adds support for Eos 3.1+ software UpdaterAtor
2.1.1.12 March 11, 2021 Adds option to append terminator to UDP packets sent through gateway UpdaterAtor
2.1.0.10 February 6, 2020 Initial Release UpdaterAtor
Response Mk2 DMX Gateways
2.1.0.6 July 30, 2024 Adds support for NFC Configuration* through ETC Set Light of:
  • Name of gateway ports
  • Pass Through if On (PTIO)
  • Last Source Only (LSO) Data Loss Behavior
*Two and Four Port non-DIN Gateways only
Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.3.1.4 May 26, 2022 Resolves an issue with external security tools Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.3.0.3 April 29, 2021
Fixture Update and RDM Improvements, performance enhancements
1.2.0.7 August 20, 2020
RDM and User Interface Improvements
1.1.3.16 February 27, 2020
Updated User Interface and Home Screen Port Indicators
1.1.2.13 January 21, 2020 Bug Fixes Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.1.1.9 July 9, 2019 Initial Release Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
Response Mk2 CPU2 DMX Gateways
3.1.0.13 July 30, 2024 Adds support for NFC Configuration* through ETC Set Light of:
Response Mk2 CPU2 One, Two, and Four Port DMX Gateways UpdaterAtor
3.0.0.7 August 31, 2023 Initial Release to support Mk2 CPU 2 DMX Gateways Response Mk2 CPU2 One, Two, and Four Port DMX Gateways UpdaterAtor
Response Snapback
2.0.0.23 March 15, 2024 Initial Release UpdaterAtor
