Gateway Software Version History
Gateways can be updated using the UpdaterAtor application via an Ethernet connection. Download the latest version of UpdaterAtor here.
DMX Gateways
Response Mk2 CPU2 DMX Gateways
Version
click for release note
Release Date Improvements
3.2.2.7 2026-09-02
  • Updated network stack
    • Gateway less likely to lock up when overloaded with network traffic
3.2.1.6 2026-06-03
  • Support for new OLED screen (DS235-F)
3.2.0.5 2024-11-06
  • Support for 8-port gateways
  • Bug fixes
3.1.0.13 2024-07-30
  • Support for NFC configuration via SetLight
    • NFC only available on 2-port and 4-port wallmount and portable gateways (not DIN)
3.0.0.7 2023-08-31
  • Initial release
Response Mk2 CPU1 DMX Gateways
Version
2.2.1.4 2026-06-03
2.2.0.3 2025-07-01
  • NFC improvements
  • Bug fixes
2.1.0.6 2024-07-30
1.3.1.4 2022-05-26
  • Resolves an issue with external security tools
1.3.0.3 2021-04-29
  • RDM and fixture update improvements
1.2.0.7 2020-08-20
  • UI improvements
  • RDM improvements
1.1.3.16 2020-02-27
  • UI improvements
    • Updated home screen port indicators
1.1.2.13 2020-01-21
  • Bug fixes
1.1.1.9 2019-07-09
  • Initial release
Net3 and Response Mk1 DMX Gateways
Version
Release Date Improvements Supported Hardware
7.1.0.9.0.5 2019-10-31
  • RDM improvements, general optimizations
7.0.1.9.0.17 2017-11-30
  • Bug fixes, optimizations
7.0.0.9.0.11 2017-03-30
  • Support for Response Mk1 DMX gateways
  • Support for Response DALI Gateway (Mk1)
  • Support for RDM transaction ACK_TIMER, used by ColorSource Relay and other RDM devices
  • Support for new LCD screen (DS220-F)
  • Removed support for Net2 mode
6.0.1.9.0.4 2024-07-17
  • Fixed a bug where loading firmware below 6.0.1 on "Net3 Only" gateway hardware may cause the bootloader to be corrupted
  • Last version to support Net2 mode (on Net2-capable hardware)
6.0.0.9.0.2 2014-04-24
  • Support for Net3 1-port Gateway (RDM version)
5.1.1.9.0.18 2014-01-16
  • Support for a larger number of RDM messages in the RDM queue
  • Removal of RDM Standby functionality
  • Bug fixes
  • Net3 4-port
  • Net3 2-port
5.1.0.9.0.16 2012-07-10
  • Screen now displays universe number for each port
  • Support for dimmer doubling
  • Ability to update Source Four LED and Desire fixtures via UpdaterAtor
5.0.0.9.0.4 2011-06-15
  • Support for a hardware component change
  • Does not include an image for Net2 mode. Do not install on devices operating in Net2 mode.
3.1.0.9.0.4 2010-06-24
  • Support for ratified sACN input and output
3.0.0.9.0.19 2010-04-29
  • Support for ratified sACN input (note: sACN output is still draft)
  • Flexible Output Patch
  • Default operating mode changed to Net3
  • Configuration saved when switching between Net2 and Net3 modes
2.0.0.9.0.14 2009-04-16
  • Support for RDM
  • Bug fixes
1.0.0.9.0.83 2008-03-06
  • Support for Net3 mode
  • Support for Net3 2-port gateway
4.0.3.9.0.31 2007-05-11
  • Support for DHCP
  • Net2 only. Net3 not supported in this version.
  • Net3 4-port
4.0.0.9.0.17 2006-06-30
  • Initial release
Net3 1-Port DMX Gateway (no RDM)
Version
4.3.2.9.0.2 2013-08-22
  • Bug fixes
4.3.1.9.0.2 2012-10-18
  • Fixed bug where updating from GCE may install a defective TFTP client, disabling future updates
4.3.0.9.0.16 2012-07-17
  • Support for configuration from GCE
4.1.0.9.0.15 2010-06-24
4.0.1.9.0.15
4.0.0.9.0.10 2008-07-23
  • Initial release
Show Control Gateways
Response MIDI Gateway
Version
2.3.2.12 2026-09-02
2.3.1.10 2026-07-02
2.3.0.8 2024-07-30
  • Performance improvements
2.2.1.8 2022-04-20
2.2.0.5 2022-01-20
  • Support for Eos family 3.1.0+ software
2.1.1.12 2021-03-11
  • Support for MIDI Notes
  • Bug fixes
2.1.0.10 2020-02-06
  • Bug fixes
    • Resolves issue with MIDI output from ACN
1.0.0.9.0.16 2018-05-10
  • Initial release
Response SMPTE Gateway
Version
2.3.2.12 2026-09-02
2.3.1.10 2026-07-02
2.3.0.8 2024-07-30
  • Adds to specify expected timecode format
2.2.1.8 2022-04-20
2.2.0.5 2022-01-20
2.1.1.12 2021-03-11
  • Decreases SMPTE acquisition time and connection time to Eos Family consoles
2.1.0.10 2020-02-06
  • Bug fixes
2.0.0.4 2019-09-12
  • Initial release
Response Serial Gateway
Version
2.3.2.12 2026-09-02
2.3.1.10 2026-07-02
2.3.0.8 2024-07-03
2.2.1.8 2022-04-20
2.1.1.12 2021-03-11
  • Adds option to append terminator to UDP packets sent through gateway
2.1.0.10 2020-02-06
  • Initial release
Net3 Show Control Gateway
Version
1.0.5.9.0.2 2013-02-21
  • Bug fixes
1.0.4.9.0.12 2011-07-20
  • Bug fixes
1.0.3.9.0.74 2010-04-29
  • Bug fixes
1.0.1.9.0.66 2008-10-09
  • Bug fixes
    • Resolves critical lockup present in version 1.0.0
1.0.0.9.0.40 2008-04-10
  • Initial release
Architectural Gateways
Response DALI Gateway Mk2
Version
1.2.1.24 2026-07-28
  • Updated color temperature control curve
  • Pulling power after updating can no longer corrupt firmware
  • Bug fixes
1.2.0.16 2026-04-30
  • Initial release
Response Analog IO Gateway
Version
2.0.3.3 2026-09-02
2.0.2.1 2026-06-03
2.0.1.0 2025-09-30
  • Bug fixes
2.0.0.23 2024-03-15
  • Bug fixes
1.0.0.10 2018-11-08
  • Initial release
Response SnapBack
Version
2.0.3.3 2026-09-02
2.0.2.1 2026-06-03
2.0.1.0 2025-09-30
  • Bug fixes
2.0.0.23 2024-03-15
  • Initial release
Response 0-10V Gateway R3
Version
4.0.2.5 2026-09-02
4.0.1.4 2026-06-03
4.0.0.3 2024-08-07
  • Initial release
Response 0-10V Gateway R1-R2
Version
3.0.0.9 2019-10-21
  • Support for configuration from Concert
  • Custom curves
2.0.0.9.0.6 2016-09-22
  • Adds ability to individually patch 0-10V outputs (sACN or DMX)
1.1.0.9.0.3 2016-02-04
  • Bug fixes
1.0.0.9.0.12 2015-09-17
  • Initial release
Response DALI Gateway Mk1
Version
1.0.0.9.0.23 2017-04-06
  • Initial release
Net3 I/O Gateway
Version
  • Bug fixes
1.0.4.9.0.12 2011-09-20
  • Bug fixes
  • Bug fixes
1.0.0.9.0.64 2008-10-09
  • Initial release
Function Description Setting
This table will not appear in the article and is used to configure the search function.
Number of Tables Prior to Search
( Integer: 0-99 )
This function determines the index of the HTML table where the search should begin. It counts the number of tables that precede the search function.
Note: KMS templates ("Caution", "Disclaimer", "Important") contain tables.
1
Search Bar Placeholder Text
( String )
The non-permanent text that serves as a hint or an example of the expected input to be entered by the user. filter results by version number, release date, improvements, or supported hardware (if applicable)
Hide Non-Matching Rows
( true / false )
This function hides the rows in a table that do not contain any text matching the search input. true
Show Table Title
( true / false )
Show or hide the element immediately preceding the table when a match is found within the table. In many articles, header elements are used to identify the following table.
Example: Paradigm Version history article
true
Highlight Matching Text
( true / false )
Highlight the matching text in yellow. true
Hide Rows with Spanned Columns (2+)
( true / false )
Automatically hide rows that contain cells spanning two or more columns. This ensures a consistent and organized presentation of the data.
Example: Product family rows in the Flat Rate article are hidden.
true
Show Table Headers
( true / false )
When a search function matches a query within a table, this function will display the corresponding header row of the table to provide context and improve readability. true
Product Line Prefix
( true / false )
Looks for search terms that start with a product line prefix followed by 'XXXX'.
Example: Flat rate article and Packing Kit article. 7184A1234 matches 7184AXXXX
false
