Net3 I/O Gateway Versions
Description
The table below lists every version of gateway software (sometimes called firmware) and its corresponding release date.
You can click the release date to download that version's release note.
Related Links
Filter:
Net3 I/O Gateway
Version
click for release note
Release Date Improvements
1.0.5.9.0.2 2013-02-21
  • Bug fixes
1.0.4.9.0.12 2011-09-20
  • Bug fixes
1.0.3.9.0.74 2010-04-29
  • Bug fixes
1.0.0.9.0.64 2008-10-09
  • Initial release
Function Description Setting
This table will not appear in the article and is used to configure the search function.
Number of Tables Prior to Search
( Integer: 0-99 )
This function determines the index of the HTML table where the search should begin. It counts the number of tables that precede the search function.
Note: KMS templates ("Caution", "Disclaimer", "Important") contain tables.
1
Search Bar Placeholder Text
( String )
The non-permanent text that serves as a hint or an example of the expected input to be entered by the user. filter results by version number, release date, improvements, or supported hardware (if applicable)
Hide Non-Matching Rows
( true / false )
This function hides the rows in a table that do not contain any text matching the search input. true
Show Table Title
( true / false )
Show or hide the element immediately preceding the table when a match is found within the table. In many articles, header elements are used to identify the following table.
Example: Paradigm Version history article
true
Highlight Matching Text
( true / false )
Highlight the matching text in yellow. true
Hide Rows with Spanned Columns (2+)
( true / false )
Automatically hide rows that contain cells spanning two or more columns. This ensures a consistent and organized presentation of the data.
Example: Product family rows in the Flat Rate article are hidden.
true
Show Table Headers
( true / false )
When a search function matches a query within a table, this function will display the corresponding header row of the table to provide context and improve readability. true
Product Line Prefix
( true / false )
Looks for search terms that start with a product line prefix followed by 'XXXX'.
Example: Flat rate article and Packing Kit article. 7184A1234 matches 7184AXXXX
false
