ColorSource Raceway DMX Output Not Working
None of my DMX outputs port on the ColorSource Raceway are outputting DMX.
One/Some of my DMX outputs on the ColorSource Raceway are not outputting DMX.
Explanation of Issue
Each DMX output on the ColorSource Raceway is essentially a 1-in, 1-out, 1-thru DMX repeater. There is a DMX power supply in the Termination box that received power and DMX from outside of the raceway and then distributes that to the first output plate.  That output plate then repeats the DMX out of the XLR connector and passes through to the next DMX output plate.  Power also daisy-chains through the plates.
If no DMX outputs are working and the LED indicator is completely off, they may not be getting power.  If the LED indicator is blinking, then they have power but are not receiving data.
  1. If no DMX outputs are working and the LED indicator is completely off, they may not be getting power.  Check the incoming power to the DMX power supply in the Termination Box.
    1. Also check the small fuse labeled "F1" on the DMX termination board in the termination box.  There is a spare fuse on the circuit board, labeled "F2". You can also order more fuses from your local Dealer using ETC part number: F9030-F.
  2. If the LED indicator is blinking, then they have power but are not receiving data.  Confirm DMX signal is good coming into the Termination box.  Also consider replacing the DMX chips on the DMX output circuit board.
    1. There are 2 DMX chips:
      1. U4 (U3 in circuit board rev E and earlier) is the chip that receives DMX from upstream. If the DMX light is blinking, this may be the problem.
      2. U5 is the chip that sends DMX out of the output port. If the DMX light is solid but there is no signal out of the output port, this may be the problem.
