How to Get Sensor+ (CEM+) Rack Config from Another Rack in the System
How to pull a Sensor+ rack configuration for one rack from another rack in the same system?
Each Sensor+ rack in a multiple rack system is aware of what configuration settings should be for all racks.  (This is only true for systems that show Rack x/y, where x= that rack's number and y= the total number of racks in the system above 1. Ex: Rack 1/2, or Rack 4/10)
If you are installing a different CEM+ processor than the one already configured, or have a need to reload the configuration to your CEM+, Please follow the steps below.
NOTE: This process will not work unless all processors in the multiple rack system are running identical versions of software.
For Full Feature Mode:
  1. Navigate to [Login] and enter PIN: 3333.  This will give you "Power User" access.
  2. Navigate to [Rack] and press enter (√).
  3. Navigate to [Get Config] and press enter (√).
  4. Select a rack number other than the one you are on to pull the configuration from. Press enter (√).
For Basic/Portable Mode:
  1. Navigate to [Configure Rack] and enter PIN: 3333.  This will give you "Power User" access.
  2. Select [Full Feature] and press enter (√).  "Are You Sure?" Select [Yes] and press enter (√).
  3. Generate Defaults for Full Feature mode using the instructions here.
  4. Follow the steps for Full Feature mode above.
Related Links/References
