How to Set DMX Loss Behavior on CEM+
Symptoms
When DMX is unplugged from the console accidentally, the lights powered by the Sensor+ (CEM+) Rack go out immediately, or don't stay on long enough if they remain on.
Explanation of Issue
The CEM+ has data loss behaviors that define what the rack does when signal is lost. The options are below*:
- Wait and Fade: upon loss of the signal, the rack will keep the last look for a designated time and then fade out. The default wait time is 180 seconds, but that can be adjusted to a shorter or longer interval. The minimum is 0 seconds, and longest is 60 minutes.
- Hold Last Look: upon loss of the signal, the rack will hold the last look until either the signal is re-acquired, or if the rack is reset.
- Play Preset: upon the loss of the signal, the rack will play a preset for a designated amount of time, and then fade out. The default wait time is 3 minutes, but can be adjusted to a shorter or longer interval. The minimum is 0 seconds, and the longest is 60 minutes.
Follow the steps below to set up the data loss behavior on your rack.*
- Press the + or - button until you see [Rack] on the bottom line of the display. Press the check mark.
- Press the - button until you see [DMX Loss Behavior] on the bottom line of the display. Press the check mark.
- Select the rack you'd like to set the behavior on using the + or - button. In a single rack system you only have one choice. Press the check mark.
- Choose which port to configure using + or -, then press the check mark.
- Choose your behavior using the + or -, then press the check mark. If using [Wait and Fade] or [Play Preset] you'll also need to define the time, and then press the check mark,
- The settings will update, and afterward you can press the << button to return to the main display
- *These options and instructions are for a CEM+ running software v3.1.3 and set up in full feature mode. Results may vary on other software versions or portable mode.
