SmartPack Fluctuating Power Phase Temperature
Symptoms
  • SmartPack loads are flickering
  • SmartPack power phase readout shows widely fluctuating numbers
  • SmartPack fan is ramping up and down more than usual
Explanation of Issue
Fluctuating temperatures for a power leg in a SmartPack often indicate an issue with the power cube (device that regulates the dimming) controlling circuits on that phase.
When metering line voltage power, follow all precautions delineated in NFPA-70E to ensure  your safety.
  1. Meter incoming voltage to verify power is stable
  2. Order a replacement power cube for that phase. Click Here for information on replacing a power cube.
