How to connect a Hog 5 console to Capture Visualization software using ArtNet
​For Console to PC Communication
Note that for ArtNet or sACN control, there needs to be supporting hardware for the corresponding universes. See How many universes can a Hog 5 console control for universe limitations for ArtNet and sACN.
1. Connect the console's FixtureNet port to the PCs Ethernet port.
2. Capture Setup
Run the Capture program on the connected computer.
If using a regular licensed copy of Capture ( .C2P)
Ensure your fixtures are patched appropriately.
Open the Universe window
Press "More" at the bottom of the window and select connectivity options.
Under ArtNet, Select your network adaptor it should display an IP address
If using a presentation file ( .exe or .app)
Launch the presentation file
Ensure fixtures have been added and patched in the universe window
3: Console Setup
Launch into your show
Open the Network window with [Setup](Network)
Right click on Processor and press settings
Open the Output Tab
Select Add Mapping
Select the starting and ending universe
Check the ArtNet box
Ensure each Hog universe is correctly mapped to the proper ArtNet subnet and universe
The console and the visualizer should be connected, If the connection is not working, double check IP addresses on the computer and the console or go to the troubleshooting section. It is advised to start Capture, then start Hog 5 PC under certain situations.
For Hog 5 PC to different PC running Capture connection
2. Capture Setup
3: Hog 5 PC Setup
Right click on DMX processor and press settings
Open the Output Tab
Select Add Mapping
For Hog 5 PC to same PC running Capture connection
2. Capture Setup
3: Hog 5 PC Setup
Open the Output Tab
Select Add Mapping
Troubleshooting
  • Disable Firewalls
Windows Defender
Press the Windows Key
Type in "Defender"
Select "Windows Defender Settings"
Select "Firewall & network protection"
Disable firewall on all 3 network types.
3rd Party software
Run third party software
Disable either temporarily, or allow all Hog 5 processes through the firewall.
Restart computer
  • Disabling the WiFi Network adaptor can resolve communications issues.
  • IPCONFIG
Hold down the windows key and press R
Type in "CMD"
Press OK
Type in "IPCONFIG"
Under your network adaptor, IPV4 it should list your computers IP address.
If under your network adaptor, "Media Disconnected" Then there is not a clean connection between your computer and the console, replace the Ethernet cable and or reseat the connection and run the "IPCONFIG" command again.
Under IPv4 address, it should list your computers IP address and subnet if using multiple devices, each device should be in the same network with unique addresses.
  • DMX TEST
It is possible that fixtures are not patched to the correct address or universe.
[Setup] (DMX) will open the DMX test window. It is advised to "Test" all DMX channels and universes for proper communication.
If data is coming through, but not correctly, check the patch matches between Capture and Hog 5.
