Supported Touchscreen Monitor List For Hog 3 consoles
Hog 3 consoles have limited touch screen compatibility, the following monitors have been tested and verified as working on Hog 3 consoles:
| Manufacturer | Model | Size | Part Number |
| Acer | T232L | 23" | UM.VT2AA.001 |
| Acer | T230H | 23" | ET.VT3HE.001 |
| Dell | P2314T | 23" | 1RNV2 |
| Dell | E2014Tt | 20" | E2014Tt |
| Dell | S2240Tb | 21.5" | 09XJW |
| Dell | P2418HT | 23.8" | P2418HT |
| ELO | AccuTouch ET1229L | 12" | All Part No. |
| ELO | AccuTouch ET1215L | 12" | E432532 |
| ELO | AccuTouch ET1725L | 17" | E103047 |
ELO |
iTouch ET1519L | 15.6" | E232070 |
| ELO | iTouch ET1919L | 18.5" | E176026 |
| ELO | Intellatouch Plus ET2201L | 22" | E107766 |
| GeChich | on-Lap 1303i | 13.3" | 13031000109 |
| Hannspree | HT225HPB | 21.5" | HT225HPBREJ01 |
| iiyama | Prolite T2252MTS | 22" | PL2252MT |
| iiyama | Prolite T2235MSC | 22" | PL2235M |
| Lenovo | T2364t | 23" | T2364t |
| VIEWSONIC | TD2340 | 23" | VS15023 |
If you have connected external displays to supplement the console's touch screens, you will need to enable them and set their screen resolution:
- Control Panel → Displays : open the Control Panel and select the Displays pane.
- Enable the displays you want to use with the Enabled buttons.
- Select a resolution for the displays from the drop-down menu
- OK : close the Control Panel.
- For the display settings to take effect, you need to restart the console. Press Quit in the Start window. When the console says that it is safe to turn it off, switch off and back on again using the powerswitch on the rear of the console.
