No dmx output from a Hoglet
A Hoglet is not sending out DMX when connected to Hog 4 PC or a Console.
A Hoglet might not be sending out DMX because the Widget in the Hoglet is not mapped to DMX universes.
If on Hog 4 PC, then the firewall or 3rd party antivirus software being on can cause the widget not to output.
If on a Hog 4 console, then connect the Hoglet and Map the widget
Map a widget, ETCnomad key, or ETC Gadget II in Hog 4 OS
If on Hog 4 PC:
  1.  Turn off all 3rd party antivirus software and Windows Firewall
  2.  Restart the computer
  3. Map the widget using the steps above
