Nomad License Driver for Hog 4 PC
The nomad license is not working for Hog 4 PC, when plugged into a computer the red LED does not light up
When installing Hog 4 PC a prompt should be shown for permission to install the nomad drivers. If this is declined the drivers will have to be installed manually.
- The individual driver can be found on the product page for Nomad
- (HASP User Setup v8.11 (Windows 10 V2004)
- Download the file
- Open and run the HASPUserSetup_v8.11.exe program
- Follow the prompts to install the driver
If installing the driver does not fix the issue contact HES technical services.
