Adding USB 3.0 Brackets to Eos Apex Consoles
USB 3.0 Bracket and Light Blocker Installation
If instructed and given parts through Tech Services, here are the steps to install the USB 3.0 brackets on Apex Family consoles. This bracket is intended to further secure the blue USB 3.0 cables into their respective locations by providing a new point to zip-tie too.
Apex 5 consoles will do projects 1 and 2
Apex 10 and 20 consoles will do all projects 1 through 4
Full list of parts with images will be at the end of the article.
All screws and standoffs should be hand tightened with hand tools
Tools Required
  • Number 1 Philips Screwdriver
  • 4.5mm Hex Driver
  • Snips to cut zip-tie access
Location of Projects
Apex 5 Apex 10/20
clipboard_eb13abc50554630cfa67d9b76ecb59f99.png clipboard_efdca5de1a021f20eb0524c7507b8ede5.png
Instructions
Project 1. Intelligent Power Board
Parts Needed
  • 2x Short 6mm Standoff- HWM927
  • 1x I/O Garage USB Bracket (apex10/20)- 4450A3147
  • 1x 4" Zip tie- HW701
  • 2x 3x6mm Pan head screw- HWM1683 (reusable)
clipboard_e3b8ae489271a0b896ca20531a5f12e2d.png clipboard_e4f248c8f31fd8f8491002cb01333da9d.png
  Location on Apex 5 Location on Apex 10/20
  • Open Control Panel
    • Identify the Intelligent Power Board
  • Remove Screws and replace with standoff
    • PN HWM927
  • Place the USB 3.0 Bracket for the Intelligent Power Board onto those standoffs and secure with screws that you removed previously
    • PN HWM1683
    • PN 4450A3147
  • Zip-tie blue USB 3.0 Cable around new bracket to hold cable in place
    • PN HW701
  • Cut extra tail off zip-tie
Project 2. Back Left USB Charging Port
Parts Needed
  • 2x Tall 19mm Standoff- HWM1841
  • 1x Back Left/Right USB Charging Bracket- 4450A3142
  • 2x Med 10mm Standoff- HWM1407
  • 1x Back Right USB Light Blocker- 4450A4077
  • 4x 3x6mm Flat head screw- HWM1851
clipboard_e74fda79be99c1d1df5b19ec654f35e59.png clipboard_e4207423163022811d9130228c10213ec.png
  • Remove the Rear Chassis Covers
    • Identify the back left USB charging port
  • Remove 4 screws holding on PCB, discard these
  • Replace front two screws with small standoffs
    • PN HWM927
  • Replace back two screws with large standoffs
    • PN HWM1841
  • On small standoffs place the USB 3.0 bracket
    • PN 4450A3142
  • Place medium standoffs on top of the bracket
    • PN HWM1407
  • Place the matte black plastic cover over the PCB lining the holes with the standoffs. The matte plastic cover should be matte/dull side up
    • PN 4450A4077
  • Secure with four screws, one on each standoff
    • PN HWM1851
    • PN HW701
Project 3. I/O Garage USB Hub
Parts Needed
  • 1x Bracket- 4450A3143
  • 1x I/O Garage USB Light Blocker- 44580A4076
    Location on Apex 10/20 only
  • Completely remove the I/O Garage
    • Identify the USB Hub for the I/O Garage
    • PN HWM927
    • PN HWM1841
    • PN 4450A3143
    • PN HWM1407
    • PN 44580A4076
    • PN HWM1851
    • PN HW701
  • (This image is shown without black cover)
Project 4. Back Right USB Charging Port
Parts Needed
  • 1x Bracket- 4450A3142
  • Open control panel and remove the two screws shown
clipboard_ed431dd3e180c8c4bbd49c702c5378bac.png clipboard_ebdaa7ee8ae6693dd4a5a603b0e72595c.png
  • Close control panel and remove block stop for armature
clipboard_eff386f5e22fb08a624508c6fec734d0e.png clipboard_e0ae66f2fcd53e232a0da35e7892129b7.png
  • Remove two screws shown
  • Remove three screws on back of console
  • Remove the side and bottom pieces of armature guide to access USB charging port
clipboard_e7f3dcf5f86224879a2232b41a35c80ae.png clipboard_ea59cd21b0505d3188b12b4d6bd94687e.png
    • PN HWM927
  • Place the USB 3.0 Bracket for the Intelligent Power Board onto those standoffs and secure with screws that were removed previously
    • PN HWM1683
    • PN 4450A3142
    • PN HW701
  • (image shown without side arm piece installed)
Total List of Materials Needed
Name of Item Part Number Amount Required for Apex 5 Amount Required for Apex 10/20 Image
Intelligent Power Board Bracket 4450A3147 1 1 clipboard_e6c32a6b0c091245d773779377f97fc41.png
Back USB Charging Port Bracket 4450A3142 1 2 clipboard_e536777c39e7427878447bdce2d90e9b1.png
Back Right USB Light Blocker 4450A4077 1 1 clipboard_ee13b56e6e48564524217a7d5afe875c7.png
Tall Standoffs (19mm hex) HWM1841 2 4 clipboard_eabf5e5b26d23876ba646992385758ccd.png
Medium Standoffs (10mm hex) HWM1407 2 4 clipboard_e7f4f826028bfd2791538a672bf2a119e.png
Short Standoffs (6mm hex) HWM927 4 8 clipboard_ee3b7db1cce61e7409f59b8da214eaccc.png
Screw (6mm Philips) Can be reused HWM1683 2 4 clipboard_e2b263969cc4e31edaa0037333aad502f.png
Screw (6mm Philips) HWM1851 4 8 clipboard_e5bc3c489428e76e422d5177142364a74.png
I/O Garage USB Bracket 4450A3143   1 clipboard_e102b11689a6e9ea6fab4e1265aa69c93.png
I/O Garage USB Light Blocker 4450A4076   1 clipboard_e735346eb5f6210a86fbf77a5035f09bd.png
Related Links/References
