How To Setup iHog OSC and Hog 5
Guide to Setting Up a Hog 5 Console and the iHog OSC app
This guide will explain the step by step process to set up the iHog app on an Apple device to be used to expand your control surface. The iHog software is a 3rd party tool.
Hardware requirements
Hog 5 series console or Hog 5 PC with wing or widget
Wireless router
Apple device
Step 1: Download iHog
Step 2: Configure your hardware
Wi-Fi Router
- Connect a wireless router to your HogNet port on the console
If running Hog 5 PC plug the router into your PC network
It is not recommended to have anything else on this network other than other Hog 5 consoles, or hardware from High End Systems like HPU. A network switch may be required depending on your setup.
Console (Choose DHCP or Static IP)
- DHCP IP (Basic, recommended if no other devices are on the network)
Navigate to control panel [Setup] (Control Panel) (HogNet)
Select “Obtain IP address using DHCP”
The console will now receive an IP address from the router
Static IP (Advanced, recommended if you already have DHCP server on your network, or if other devices are already on the network)
Select “Static IP”
Configure your console, and other preexisting devices on your network to be in range of each other
By default, HogNet IP range is 172.31.0.XXX
Configure your router for a static IP within the range of your console network. Refer to your router’s manual for steps to configure
Connect your device to the Wi-Fi router, and set a custom IP that is within the range of your network. The steps to do this will be different from device to device
Step 3: Configuring Software
Console
Open the network window [Setup](Network)
Right click on the console, select (Settings)
Select the “Open Sound Control” tab.
Enable OSC in and OSC out
Ensure the port numbers are different,
Recommended to use input port: 7001
Recommended to use output port: 7002
Input your phone or tablet IP address into the IP address box under the output panel
To see your local IP, open the iHog app on your device, then press “Device” on the side bar.
Device
Make sure device is connected to the WiFi router
Open iHog app and select “device” from the side bar.
Populate the Console’s HogNet IP address field
To see your consoles IP, press [Setup](Control Panel)(HogNet)
Populate console input port. Recommended to use the default 7001
Populate console output port. Recommended to use the default 7002
Apply settings.
Using the apps back button you can now select Programming or Playback from the Front Panel section.
Related Links/References
- Section 22: Open Sound Control
- How to Setup Touch OSC and Hog 4
- How to Setup a Stream Deck and Hog 4
- How to Setup Numeo Remote OSC and Hog 4
