Green display on Hedgehog 4
The display has a green background.
This can be caused by the LVDS cable being loose or broken or the display it self.
  1. Try reseating the cable on the display and the motherboard
  2. If the above does not clear the issue, then a new display will be needed.
    Contact your local HES dealer or service provider to purchase a new display or set up a repair to replace the display.
    If you need to find a local service provider, please click here to use Find A Dealer.
