| 3.3.10 |
September 22, 2026 |
Key Enhancements:
- Eos v3.3.10 is a patch release containing minor features, improvements, and bug fixes.
- Out of an abundance of caution, Apex consoles with fader firmware v1.1.4.2 will be prompted to move to v1.1.3.1. We continue to investigate intermittent field reports and will release new firmware when fixes are ready to apply.
- ETC recommends updating to Eos v3.3.10 as production schedules allow.
Bundled Components:
- Eos v3.3.10 Build 28
- Augment3d v1.4.10.3
- Fixture Library v3.3.10.1
ETCnomad Specifications:
ETCnomad Hardware Specifications
macOS Compatibility:
- macOS Sequoia (15.x), macOS Sonoma (14.x), macOS Ventura (13.7)
Windows Compatibility:
- Windows 11, Windows 10 (64-bit), Windows 8 (64-bit), Windows 7 (64-bit)
Software:
Latest Fixture Library:
v3.3.x Documentation:
v3.3.x Reference Material
| 3.3.9 |
July 20, 2026 |
Key Enhancements:
- Eos v3.3.9 is a patch release containing minor features, improvements, and bug fixes.
- Additions and improvements to third-party OSC TCP connections.
- Improvements to fixture position data from a Lightwright import.
- A fix for an issue introduced in 3.3.7 where cues with channels running in a downtime would make the previous cue red until the fade was complete.
- A fix for an issue introduced in 3.3.7 where Cue Execute String causes extra spaces and backslashes while typing command.
- ETC recommends updating to Eos v3.3.9 as production schedules allow.
Bundled Components:
- Eos v3.3.9 Build 25
- Augment3d v1.4.9.1
- Fixture Library v3.3.9.2
Software:
| 3.3.8 |
June 3, 2026 |
Key Enhancements:
- Eos v3.3.8 is a patch release containing minor features, improvements, and bug fixes.
- Adds last OSC message obtained in Diagnostics
- Fixture Wizard now defaults additive color mix values to 255
- New language when updating firmware of Update vs Repair
- ETC recommends updating to Eos v3.3.8 as production schedules allow.
Bundled Components:
- Eos v3.3.8 Build 7
- Augment3d v1.4.6.4
- Fixture Library v3.3.7.2
Software:
| 3.3.7 |
May 27, 2026 |
Key Enhancements:
- Eos v3.3.7 has been removed from distribution as of 2026-06-01. A critical fault was found where a user could inadvertently remove output licenses from their device by updating component firmware. Users are recommended to install Eos v3.3.8, in which the issue has been removed.
Bundled Components:
- Eos v3.3.7 Build 40
Software:
| 3.3.6 |
April 14, 2026 |
Key Enhancements:
- Eos v3.3.6 is a patch release containing minor features, improvements, and bug fixes.
- Added Quick Filters in diagnostic window search bar
- Reintroduced diagnostic window showing firmware of modules connected to Eos
- Resolved crash when loading Pixel Map thumbnails
- ETC recommends updating to Eos v3.3.6 as production schedules allow.
Bundled Components:
- Eos v3.3.6 Build 60
- Fixture Library v3.3.6.2
Software:
| 3.3.5 |
January 20, 2026 |
Key Enhancements:
- Eos v3.3.5 is a patch release which includes new Video Stream options, some additional minor features, and over a hundred bug fixes:
- Video Stream Input
- Video continues to grow as a core part of productions, and having streams accessible from your lighting console is more useful than ever. In v3.3.5, you can send your favorite SRT and RTSP streams to Eos and use them in a variety of ways:
- Video streams can be used as a Pixel Map layer, giving your rig the ability to stay in sync with video content.
- Need a heads up view from your backstage feed, or your new RigPOV camera? Simply open a new Video Stream tab, or embed several streams into your Magic Sheets for ultimate control.
- Streams can be represented in your Augment3d space by mapping them to materials and displaying them on any surface.
- Need additional programming references when working in Augment3d? With camera overlays with opacity, you can see your front-on stream lined up with your Augment3d model, or pre-light in Augment3d by playing that rehearsal room video alongside.
- With video streams tied into so many Eos tools, all points of view come to you
- Additional Features
- Undo and Redo options have been added to the Magic Sheet Editor.
- Setup has a new Protect Wheels in Blind option.
- Color configuration can be copied between device profiles.
- GDTF imports now include color configuration information.
- You can add favorite file locations in Eos on Windows and macOS.
- Eos can act as an OSC TCP Client.
- OSC Health subscriptions are now available.
- Flagging logs with [Displays] & [Record] now sends an OSC event.
- Improvements have been made to the fixture wizard.
- Diagnostics [Tab 99] has been modernized and added to the tab menu.
- Non-usable external NICs are no longer shown in Shell > Networking
- ETC recommends updating to Eos v3.3.5 as production schedules allow.
Bundled Components:
- Eos v3.3.5 Build 69
- Augment3d v1.4.5.15
- Fixture Library v3.3.5.2
Software:
| 3.3.4 |
December 2, 2025 |
Key Enhancements:
- Eos v3.3.4 is a patch build which fixes several critical issues found in the field:
- Fixes an issue where cues with over 1000 channels may not start their marks in the correct cue.
- Fixes a rare hang when loading a corrupted show file.
- Fixes other mark, effect and display bugs
- ETC recommends that any users already in the Eos v3.3 branch update to v3.3.4 as soon as possible.
Bundled Components:
- Eos v3.3.4 Build 21
- Augment3d v1.4.3.1
- Fixture Library v3.3.0.223
Software:
| 3.3.3 |
October 16, 2025 |
Key Enhancements:
- Eos v3.3.3 is a patch build which fixes several critical issues found in the field:
- Fixes an issue where, if palettes had not been created or merged previously, they would not be stored after Eos was restarted.
- Fixes crashes related to moving Subs and the Device Health Magic Sheet object.
- Fixes issues where Expansion Processors could get out of sync.
- Fixes an issue where Snapshots with faders stored could flip Subs to Additive.
- ETC recommends that any users already in the Eos v3.3 branch update to v3.3.3 as soon as possible.
Bundled Components:
- Eos v3.3.3 Build 10
- Fixture Library v3.3.0.215
Software:
| 3.3.2 |
October 7, 2025 |
Key Enhancements:
- Eos v3.3.2 is a patch build which brings fixes, optimizations, and minor improvements across the platform:
- Fixes for rare hangs and crashes.
- Display optimizations for large show files.
- GDTF import fixes.
- Processor object for Magic Sheets.
- New [GoToCue] {Timecode} syntaxes.
- ETC recommends updating to Eos v3.3.2 as production schedules allow.
Bundled Components:
- Eos v3.3.2 Build 36
- Augment3d v1.4.2.3
- Fixture Library v3.3.0.212
Software:
| 3.3.1 |
September 18, 2025 |
Key Enhancements :
- Eos v3.3.1 is a patch build which includes fixes to critical issues found in the field.
- ETC recommends updating to Eos v3.3.1 as production schedules allow.
Bundled Components:
- Eos v3.3.1 Build 11
- Augment3d v1.4.0.89
- Fixture Library v3.3.0.191
Software:
| 3.3.0 |
August 19, 2025 |
Key Enhancements :
- Eos Expansion Processing added.
- Output processing to be shared across multiple devices on the network.
- Allows much higher system counts than previously possible.
- Deterministic architecture with the option for full-tracking backups.
- Support for Eos Expansion Processor hardware.
- Clearer network requirements published to help with deployment of expansion processing.
- Device and connection health reporting added.
- Magic sheet editing toolbar added, along with other magic sheet improvements.
- Fader tab now more closely reflects fader hardware, and supports multi-touch.
- Eos Fixture Wizard added to streamline creation of common types of fixture profiles.
- Pixel map media synchronization is now possible across a multiconsole session.
- LED parameter curves can now be changed in the fixture editor.
- Output of fixtures can now be specified in Augment3d, in lumens.
- Augment3d camera touch gestures improved and now support multi-touch.
- Remote Startup and Shutdown options have moved from the shell to within Eos (Setup > Device Settings > Config).
- Console manuals now include full OSC dictionary and software release notes.
- It is now possible to select a sticky boot-up mode in the ECU (i.e. Primary, Client) that the device will always boot into, instead of always booting into the last mode selected.
- Movement of fixtures controlled via XYZ coordinates has been optimized to minimize unwanted flips.
- XY color parameters can now be edited and recorded with up to four decimal places of precision.
- UV color emitters in fixtures now home to 0 by default.
- More display options for the Apex Processor added.
- Maximum number of Groups, Sub, and Cue Lists increased to 9,999.
- Maximum number of channels increased to 100,000.
- Maximum number of addresses increased to 150,000.
- Over 700 bug fixes and improvements.
Bundled Components:
- Eos v3.3.0 Build 549
- Fixture Library v3.3.0.189
Software:
| 3.2.12 |
June 3, 2025 |
Purpose :
- Eos v3.2.12 is a patch build which adds support for the TK 10 Target Key rackmount accessory.
- Support for Apex FP.
- ETC recommends updating to Eos v3.2.12 as production schedules allow.
Bundled Components:
- Eos v3.2.12 Build 1
- Augment3d v1.3.11.3
- Fixture Library v3.2.10 Build 23
- macOS Sonoma (14.x), macOS Ventura (13.x), macOS Montery (12.x), macOS Big Sur (11.x), macOS Catalina (10.15.x)
Software:
Terminal 3.2.x Fixture Library:
v3.2.x Documentation:
v3.2.x Reference Material:
| 3.2.11 |
May 20, 2025 |
Purpose :
- Eos v3.2.11 is a patch build which includes:
- Support for the TK 10 Target Key Accessory.
- Fixes for Magic Sheet object parameter and category selection.
- Magic Sheet objects can use the Notes and Scenes fields.
- Multi-console sync and stability improvements.
- Other improvements and bug fixes.
- ETC recommends updating to Eos v3.2.11 as production schedules allow
Bundled Components:
- Eos v3.2.11 Build 27
Software:
| 3.2.10 |
Nov 22, 2024 |
Purpose :
- Eos v3.2.10 is a patch build which includes:
- Magic Sheet improvements:
- New Mirror Tool.
- Redesigned Flip Tool.
- New Stretch Tool.
- Non-intensity parameters can be mapped in object fields.
- Reorganization and cleanup of editor menus.
- Show preview of objects when placing them from the editor.
- Augment3d improvements:
- Touch gestures can be used to change the camera position and orientation.
- The Materials dock is now open by default.
- Bump button option for “On” for submasters.
- Smoother transitions with Track SEM Focus Palettes, allow nesting of Track SEM Focus Palettes into Presets.
- ETC recommends updating to Eos v3.2.10 as production schedules allow.
Bundled Components:
- Eos v3.2.10 Build 36
- Augment3d v1.3.10.6
- Fixture Library v3.2.9 Build 14
Software:
| 3.2.9 |
Aug 28, 2024 |
Purpose :
- Eos v3.2.9 is a patch build which includes:
- Fixes for a few edge-case crashes in multiconsole sessions.
- Improvements for CSV exports, CSV imports, and GDTF imports.
- Gobo search menu added to Gobo Wheel editor in Patch > Attributes.
- New Magic Sheet options for command line User # and Label.
- ETC recommends updating to Eos v3.2.9 as production schedules allow.
Bundled Components:
- Eos v3.2.9 Build 16
- Augment3d v1.3.8.7
- Fixture Library v3.2.8 Build 12
Software:
| 3.2.8 |
May 22, 2024 |
Purpose :
- Eos v3.2.8 is a patch build which includes:
- A revamped gobo search in Patch > Database > Gobo.
- Pixel Map fixture layout import and export via CSV.
- Element 2 fader board firmware v2.0.2.3.
- Other bug fixes and improvements.
- ETC recommends updating to Eos v3.2.8 and applying new firmware as production schedules allow
Bundled Components:
- Eos v3.2.8 Build 25
- Fixture Library v3.2.7 Build 18
Software:
| 3.2.7 |
April 4, 2024 |
Purpose :
- Eos v3.2.7 is a patch build which includes:
- Reinstated Rosco and GAM library assets.
- Bug fixes and improvements in Patch, GDTF import, and Augment3d.
- Firmware for Apex consoles and Processor, to increase stability.
- Fixed a bug where deleting channel parts in Patch would crash Eos.
- ETC recommends updating to Eos v3.2.7 and applying new firmware as production schedules allow.
Bundled Components:
- Eos v3.2.7 Build 18
- Augment3d v1.3.6
- Fixture Library v3.2.7 Build 11
Software:
| 3.2.6 |
February 26, 2024 |
Purpose :
- Eos v3.2.6 is a patch build that improves GDTF imports, includes firmware for Apex keypads and Windows 10 based Element 2 playback modules, and adds a number of other bug fixes and improvements. ETC recommends updating to Eos v3.2.6 and applying new firmware as production schedules allow.
Bundled Components:
- Eos v3.2.6 Build 29
- Augment3d v1.3.6
- Fixture Library v3.2.5 Build 20
- macOS Ventura (13.x), macOS Montery (12.x), macOS Big Sur (11.x), macOS Catalina (10.15.x)
Software:
| 3.2.5 |
October 25, 2023 |
Purpose :
- Eos v3.2.5 focuses on critical fixes and integrates firmware for some Apex modules. ETC recommends users upgrade when production schedules allow to receive the latest bug fixes and improvements.
Key Enhancements:
- [Shift] & [Stop/Back] could put Primary and Client devices in different active cues ‐
- Workaround: a [GoToCue] [##] [Enter] will re-sync all devices
- Network storage directories produced errors when executing a save
- [Go] and [Stop/Back] presses on Apex main fader pair can be missed while backlights are fading ‐
- Fix: update the Apex Main Playback module to v1.1.3.1 firmware from the Shell
- Workaround: ensure Apex is awake (not dimmed) before executing [Go] or [Stop/Back] commands. [Shift] or [Clear] are safe ways to wake up the console.
- Recalling a Snapshot with Blind Spreadsheet view was not switching format to Spreadsheet
- New From Template now preserves the Park buffer through the file load
- CMY color changes were not causing a Live Move
- ETCnomad devices could accumulate false instances of wifi adapters
- Updating a Palette reference currently used by a Sub would Sneak to the previous Palette value
- Added {Allow App Connections} and {Visible to Mobile Apps} to the Macro Editor
Bundled Components:
- Eos v3.2.5 Build 13
- Augment3d v1.3.5
- Fixture Library v3.2.4 Build 115
Software:
| 3.2.4 |
September 20, 2023 |
Purpose :
- Eos v3.2.4 is a patch build with close to a hundred bug fixes and improvements, including basic fixture import in General Device Type Format (GDTF).
- General Device Type Format (GDTF) Import
- GDTF fixtures can be imported from the Eos file browswer via File > Import > GDTF Fixtures. Once imported, they can be patched and used in your show file similar to any other custom or usergenerated fixture profile. GDTF fixture imports do not include 3D models for use with Augment3d. Note: Parameter types and DMX ranges may need to be edited after import. Some imports may dynamically create parameters in the fixture profile as needed. See the following ETC support article for additional information on importing GDTF fixtures: support.etcconnect.com/ETC/Consoles/Eos_Family/Software_and_Programming/GDTF
Key Enhancements:
- Basic fixture import via General Device Type Format (GDTF).
- Fixture editor improvements and bug fixes.
- Show control list bug fixes.
- Magic sheet bug fixes.
- Shell popup dialog improvements.
- Apex display reliability improvements.
- Fixed: ‐
- Pixel maps could use additional emitters when at source points of the gamut.
- Disabling WiFi in macOS could cause Eos to hang or not launch.
- Partitions with thousands of channels could make the partition display sluggish.
Bundled Components:
- Eos v3.2.4 Build 58
- Augment3d v1.3.3 Build 2
- Fixture Library v3.2.4 Build 108
Software:
| 3.2.3 |
July 13, 2023 |
Purpose :
- Eos v3.2.3 focuses on critical fixes and optimizations for playback, synchronization in multiconsole systems, and other improvements. ETC recommends that users who have upgraded to v3.2.x move to v3.2.3 as soon as they are able, and users moving from v3.1.5 or earlier upgrade directly to v3.2.3.
Key Enhancements:
- Playback, multiconsole, and synchronization bug fixes & improvements:
- Changing any Setup option could cause some address levels to snap to 0 and then back again.
- Extremely long file transfer times could be experienced on multiconsole systems.
- Undo could experience significant slowdowns. ‐ When the PSD is visible, it could slow down the fade engine refresh rate on very large shows. ‐ Channel Filters with a very large number of channels could cause low sACN refresh rate.
- Effects playback, out-of-sequence, and data management optimizations. ‐ General cue-firing performance improvements. •
- General improvements: ‐
- In Patch > Universe Preview, the default view is now Port/Offset, and the controls have been moved into the UI.
- In previous versions, setting the per-channel shutter order in Patch > Attributes altered the shutters in the Augment3d model separately from the fixture profile. This has been fixed. A reminder that adjusting Augment3d shutters to match reality is done in the fixture profile editor. See this ETC support article: The Complete Guide to Shutters in Augment3d.
- Trackball use has been improved.
- Console sounds on Mac have been fixed.
- Over 100 bug fixes and improvements.
Bundled Components:
- Eos v3.2.3 Build 19
Software:
| 3.2.2 |
June 6, 2023 |
Purpose :
- Eos v3.2.2 fully replaces v3.2.1 to fix a critical firmware upgrade issue that can cause devices to lose their license (output count). Users who have already upgraded to v3.2.1 should move to v3.2.2 as soon as possible. Users upgrading from v3.2.0 or earlier should skip v3.2.1 and move directly to v3.2.2.
- Only products built after July 2022 that use the 4390B5614 or 4390B5714 Intelligent Power Board IMX RT circuit boards can be affected:
- Apex Processor
- Eos Remote Interface
- Gio @5
- Ion Xe
- Ion Xe 20
- Ion Xe RPU
- Element 2, Apex consoles, Programming Wings, Pucks, and legacy hardware are not affected.
Key Enhancements:
- Critical firmware upgrade fixes.
Bundled Components:
- Eos v3.2.2 Build 25
- Augment3d v1.3.1 Build 2
- Fixture Library v3.2.0 Build 75
Software:
3.2.1
May 17, 2023
Key Enhancements:
- Eos v3.2.1 includes firmware v2.2.0 for newer console I/O cards and Gadget II. This firmware restores missing functionality from devices made after July 2022:
- RDM functionality on DMX ports.
- ETC device firmware updates via DMX ports.
- Local contact closure and relay functionality.
- Dimming of face panel backlight and indicators.
- Live dimming of Littlite during brightness level adjustments.
- With this firmware installed on affected devices, all consoles and Gadgets will have full feature sets, regardless of ship date.
- Bug fixes and performance improvements.
- The Eos Family User Manual is now available in Spanish.
Bundled Components:
- Eos v3.2.1 Build 12
Software:
(Unavailable)
3.2.0
April 14, 2023
Key Enhancements:
- Some items from other areas of Setup have been moved into Device Settings, to encapsulate all settings that affect an Eos device.
- Device Profiles.
- Network interface settings have been moved from the shell into Setup > Device > Network.
- Many settings no longer require a restart.
- sACN and Art-Net output protocol configurations have been moved from the Shell into Patch > Protocols.
- sACN and Art-Net support multicast, broadcast, and unicast output, individually or simultaneously, on a per-universe basis.
- sACN supports per-universe priority overrides.
- sACN supports disabling the per-address priority packet from being sent on a global or per-universe basis.
- Color Configuration has been added to Patch > Fixtures for additive luminaires.
- Fixtures with factory-provided Color Configurations are indicated in the Fixtures list with a small CIE XY icon.
- Eos will dynamically make gamuts out of the additive color parameters defined for a fixture profile.
- CIE XY control has been integrated into Eos’ color tools, and via the command line.
- Kodak ProPhoto space is now a toggleable layer.
- Augment3d accepts direct MVR imports from Vectorworks for fixture and model data.
- glTF imports are accepted from Capture 2022.0.29 and later.
- Augment3d has added Zones, which are volumes that can be added to the model space, and interact with fixtures whose beam intersects the Zone.
- Zones use a new temporary data type, called Override Data.
- Focus Palettes have a new "Track SEM" column to track Scenic Element Movable channels.
- Augment3d materials can have individual overrides applied to sub-objects.
- Objects in Augment3d can now have their pivot point redefined.
- Asset imports come through a unified popup.
- Tethered devices now respect the connected Eos’ extinguish mode.
- A search has been added to the Macro Editor.
- Custom Encoder Map logic for maps with multiple fixtures assigned now uses “OR” logic, instead of the previously required “AND” logic, when applying maps to a channel selection.
- A template show file can be defined in the Shell > Settings > General.
- Introduced Update Intensity Cue Only as a modifier in the Update dialog.
- Introduced Preheat Preset
- WiFi Remote settings are no longer in the Shell, and only exist within Setup > System > Mobile Apps
- Eos Software and Library downloads which are "double-zipped" can be installed without removing the first zip.
- Importing .svgz files is supported.
- Record Effects In Presets is a toggleable option in Setup > User > Record Defaults.
- Effects received many bug fixes.
- Cue Alert timing allows a user to input or learn timing between manual [Go] presses.
- Apex Scroll Faders are independently pageable by pressing and holding a [Page +/-] key and moving any scroll fader.
- Sneak commands accept [Delay] in their execution.
- On-board User Manual improvements.
- Deleting a cue with an attached Scene will move that Scene to the subsequent cue.
- Zoom tools were added to the Pixel Map Editor (Tab 9) and Pixel Map Preview (Tab 10) in the config gear.
- OSC commands exist for controlling channels via Override Data.
- Hue & Saturation encoders have returned when using CMY fixtures.
- Filters have more prominent graphics on the CIA Parameter tiles when active, and while editing.
- Simplified software versioning in the shell, with a popup for more details.
- Various CSV export improvements.
- There is a Flexi option in Staging Mode to show only channels affected by Staging levels, called {Stage}.
- The device clock can be changed by clicking or touching the clock in the top bar of any monitor. Time is still managed by the OS on ETCnomad installations.
- ~700 bug fixes, performance enhancements, and optimizations.
- ETC Net2 (EDMX), AVAB UDP, Draft sACN, iRFR Classic, iRFR Preview Classic, and aRFR Classic have been depricated.
Bundled Components:
- Eos v3.2.0 Build 291
- Augment3d v1.3.0 Build 83
- Fixture Library v3.2.0 Build 72
Software:
3.1.5
October 18, 2022
Key Enhancements:
Bundled Components:
- Eos v3.1.5 Build 8
- Augment3d v1.2.3 Build 2
- Fixture Library v3.1.3 Build 6
- macOS Ventura (13.x), macOS Montery (12.x), macOS Big Sur (11.x), macOS Catalina (10.15.x), macOS Mojave (10.14.x)
Software:
Terminal 3.1.x Fixture Library:
v3.1.x Documentation:
v3.1.x Reference Material:
3.1.4
August 22, 2022
Key Enhancements:
- This software release supports redesigned internal components, and contains no Eos software features.
- Adds support for redesigned iMX internal components.
- Support for Gadget II CPU 2
- It is not necessary to upgrade from Eos v3.1.3 unless a user intends to network with a newer console using those redesigned iMX internal components.
- For more information, please see the Eos Shipping Update page.
Bundled Components:
- Eos v3.1.4 Build 4
- Eos Fixture Library 3.1.3 Build 5
Software:
3.1.3
July 18, 2022
Key Enhancements:
Bundled Components:
- Eos v3.1.3 Build 8
- Eos Fixture Library 3.1.2 Build 2
Software:
3.1.2
(With Augment3d 1.2.2)
May 31, 2022
3.1.1
(With Augment3d 1.2.1)
March 24, 2022
- Support for Eos Apex 5, Apex 10, Apex 20, Apex Processor, and Eos Remote Interface.
- Workspace layout tools have been improved.
- Encoder displays have been improved.
- You may now connect multiple Response Show Control gateways via USB, including several of the same type.
- Magic Sheets have a high quality mode (enabled by default) and lower quality mode, for improved render times of complicated Magic Sheets.
- Tethered Augment3d computers will automatically reconnect with their console after a power cycle.
- In Setup > MIDI Notes, Eos can be set to ignore Active Sense (0xFE) and Beat Clock (0xF8) messages (both are ignored by default).
- Augment3d now supports fixtures that use moving mirrors for focus.
- Many bug fixes and optimizations have been included.
3.1.0
(With Augment3d 1.2.0)
Software Introduction Video
November 16, 2021
- Minimum supported version for Windows10-based Ion XE, Ion XE 20, Gio @5, Element2
- The Undo history persists through saves, as well as through devices joining and leaving the session.
- User-defined Encoder Maps can be created in Tab 40. When Custom mode is enabled, the encoders will use Encoder Maps based on channel selection. A default Encoder Map can be defined in Setup.
- A color picker widget has been added to Color encoder category pages.
- Custom Direct Selects are now full target lists, with a new editing tab (Tab 39). They can be used anywhere Direct Selects are populated, and multiple Custom Direct Select layouts can be displayed at once.
- Custom Direct Selects can utilize console hard keys, softkeys, and navigation buttons–including “Jump To.”
- Many target lists now include an Icon field, which can be displayed in Direct Selects or Magic Sheets.
- Enhancements have been made to the Magic Sheet & Icon image library manager, including folders and editing tools.
- The console brightness settings have been redesigned – including three brightness presets and extinguish mode – which are all macro-able. Quick-access to the brightness settings is available anywhere in the system by pressing & holding [Displays].
- Fader Wing Groups have been added, which will constrain paging to wings in the same group.
- Resize parameter columns in Live table view.
- Timecode has been moved to its own column in the PSD. The timecode preview in the top bar is now a dropdown menu, allowing each user to view a specific list.
- In the Magic Sheet editor, [Tab] now moves the cursor between fields.
- On Magic Sheet shape objects, the Text field may now be used.
- Magic Sheet Cue Active/Pending objects may now be associated with cue lists.
- Snapshots now allow granularity for storing fader mapping and content state.
- Offset functions have been expanded, including usage with subgroups.
- {Stop Effect} can now be placed on the command line using [Shift] & [Effect].
- A dedicated port for third-party OSC communication can be enabled in the shell.
- Eos on Windows or macOS will now show all available NICs.
- All NICs are now available for Art-Net output.
- Augment3d model objects can now be assigned colors and materials. A new Materials tab is available in the Augment3d editor to modify and manage materials. Stock materials are included, and more can be downloaded from ETC’s website.
- Augment3d now imports conventional fixture shutter cuts from a Vectorworks Plugin export.
- Augment3d now includes fixtures that are omni-directional sources (like sconces and chandeliers).
- Augment3d’s position and orientation (global and local) for channels are now shown as columns in Patch, and indicate nested positions when used with SEMs.
- Support for Icelandic and Polish alpha-numeric keyboards.
- Over a thousand bug fixes, additions, and improvements.
3.0.3
December 15, 2021
- Bug Fixes:
- [Group X Cell 1 Thru +] crashes all devices
- Critical bug fixes for Net3 / Response show control gateway connections
- Pixel map video playback memory leak fixed
- Merging from an ESF/ESF2 show file could be treated as a file open
3.0.2
March 25, 2021
- Eos v3.0.2 corrects an issue on Gio @5 and Eos Motorized Fader Wings (10 & 20) where the motor could fight the user when adjusting fader levels.
Bundled Components:
- Eos v3.0.2 Build 6
- Augment3d v1.0.1 Build 8
- Eos Fixture Library 3.0.1 Build 2
3.0.1
(With Augment3d 1.0.1)
January 28, 2021
- Fixed a crash that could occur when using multiple monitors on macOS
- Added an option to revert Blind Next/Last navigation to pre-v3.0.0 behavior
- Warnings added for video formats that cannot play in reverse
- Added support for Vectorworks 2021 and SketchUp 2021
- New Augment3d models (Desk Lamp, Standing Lamp, Pendant, Down Light, Sconce, Fluorescent)
- Minor bug fixes
Software Unavailable
3.0.1 Release Note
3.0.0
(With Augment3d 1.0.0)
August 19, 2020
- Augment3d, a new Eos tool for configuring and focusing virtual representations of fixtures in a 3D environment
- Graphical user interface (GUI) redesign, including a new color scheme, and updates to Setup,
- Fader Configuration, the CIA, and encoder displays
- Effects variables, which can be inserted in StepBased and Absolute effects to allow modification on a per-cue basis
- Staging mode, allowing you to preview changes temporarily before committing the levels to Live or Blind, or reverting them
- New default show file format ESF2, along with ESF3D for Augment3d bundles, while retaining ESF for legacy support
- Support for reordering tabs within a frame
- Magic Sheet Editor improvements
- A new graphical display for Offset channel patterns, support for Offset Cue commands, and other Offset improvements
- Revised About tools, especially for presets and palettes
- Optional expanded fader ribbon controls
- New REC709 and REC2020 color templates for CIE color spaces
- Parallel installs of Eos v3.0.0 and later with Eos v2.9.X
Critical Issues:
Important Notes:
- Virtual Media Server: Starting in version 3.0.0 of Eos Family software and going forward, Pixel Map video and gif media will no longer play backwards. The {Loop Reverse} and {Once Reverse} options in the layer will no longer force video and gifs to play back in reverse. For more information: Pixel Map Videos Will No Longer Play In Reverse in v3.0.0 and Up
2.9.3
June 8, 2022
- Eos v2.9.3 contains minor bug fixes and fixture libraries for XP-based hardware. 2.9.3 may also be installed on Windows 7-based hardware alongside Eos 3.x. Eos v2.9.3 cannot be installed on Windows 10-based Eos hardware.
- ETCnomad driver maintenance
- The effect editor no longer stops touch input above the center of the screen
- Minor bug fixes
- Consoles and ETCnomad PC
- ETCnomad only: Windows 10 (64-bit)
- ETCnomad only: Windows 8 (64-bit)
- Windows 7 (64-bit)
- Windows XP
- ETCnomad Mac
- macOS Ventura (13.0)
- macOS Monterey (12.0)
- macOS Big Sur (11.0)
- macOS Catalina (10.15)
- macOS Mojave (10.14)
2.9.2
December 8, 2020
- Eos v2.9.2 contains minor bug fixes and fixture libraries for XP-based hardware. 2.9.2 may also be installed on Windows 7-based hardware alongside Eos 3.0.0 and later software versions
- Added support for CEM3 v1.7.2
- Minor bug fixes
2.9.1
October 3, 2019
- Added support for macOS Catalina (10.15)
- Custom OSC TX/RX strings may be assigned on a per-cue-list basis
- Exceed Limits option for shutters temporarily overrides the thrust / angle end-of-travel controls
- Network List Receive option in Setup > Show Control allows all lists to be enabled/disabled
- Send MIDI Raw option in Setup > Show Control globally disables / enables sending MIDI strings
- Improvements to ASCII import / export
- Generic color calibration can now be disabled for RGBW fixtures in Patch
- Pixel Map performance enhancements
- Bug fixes
2.9.0
August 19, 2019
- ETCnomad dongle and ETCnomad Puck base output count has been increased from 512 to 1024
- A redesigned Home Screen, combining Workspace Layout and Display Picker tools
- New Console Status Display (CSD) in the CIA to monitor console errors and warnings
- Two new modes for Absolute effects: Build and Break
- 64-bit 2.9 Mac installer, to comply with Apple's upcoming discontinuation of support for 32-bit apps
- “Save Logs” is now a top level entry in the CIA, rather than an option in “Export”
- A list of common macro commands in the Macro Editor
- New Magic Sheet Objects for Response Analog IO Gateway status and Time Code status
- Optional ESF2 file format for improved show file compression
- Support for merging ASCII data into show files
- Bug fixes
Eos v2.9.0 is released for Windows 7 and XP-based hardware. As the final feature release for XP, there will be other releases forthcoming for 2.9 (even after 3.0 is released) to support new network hardware as needed, but these are not anticipated to include new features, or modifications to existing ones. As such, 2.9 is largely a clean-up release, addressing a number of anomalies across the application software. Please note that we will continue to make fixture library patches available for 2.9.
Eos v2.9.0 is incompatible with Mac OS Catalina 10.15. An Eos v2.9.1 will be released with Catalina support.
2.8.3
May 6, 2019
The purpose of 2.8.3 is to address a number of issues related to multi-console sync, undo and effects playback. It is highly recommended that users running 2.8 branches update to this software version as soon as
possible.
2.8.2
Feb 28, 2019
It is highly recommended that users running 2.8 branches update to version 2.8.3 as soon as possible.
2.8.1
Feb 5, 2019
2.8.0
Jan 3, 2019
- New fixture editor
- Improved relative effect editing tools
- Ability to store effects in cue parts
- Limited expanded magic sheet
- A PSD option to suppress follow/hang indicators
- Unsaved changes in the current showfile warning
- Ability to direct UDP and OSC commands to multiple destinations
- Improved "Best Spectral Match" controls
- Bug Fixes
2.7.4
Oct 8, 2018
2.7.3
Aug 16, 2018
| 2.7.2 |
Jun 28, 2018 |
- Enabling OSC USB Devices Added to Setup
- For all summary views, including flexi cells off, Eos will display content when using referenced data on a majority basis.
- Added syntax support for [.] [0] to select only the master channel of multicell fixtures
| 2.7.1 |
May 31, 2018 |
- It is recommended all users of 2.7.0 or 2.7.1 upgrade to version 2.7.2+ at the earliest possible time due to a critical bug where Undo can revoke changes beyond the desired undo point if Tab 100 (the manual) is open.
- Bug Fixes
- Element 2 support
2.7.0
May 17, 2018 |
- Syntax to set a range of times over Show Control Events
- Cues triggered by follow/hang times are graphically identified in the PSD
- Change default partitions to 901 through 903
- Fan timing across cue and cue part ranges
- Apply a range of palettes/presets or levels across a range of effect steps/actions
- Color Swatches on Direct Selects should respect the gel settings
- Add display configuration tools to the Cue List Index
- Online user manual
- Output viewer to display levels for addresses by universe
- Allow user defined ranges for rate, effect size and effect rate faders
- Add a lock to About to restrict content to channel or record content specified
- Text search of content by label
- Add smoothing function to virtual master channel controls
- Add Global Effects Master option to fader configuration, with channel and content filters
- Add configuration tools to Virtual Fader controls
- Reorganize Setup
- Add Delete Unused to fixture list in patch
- Dropdown above CIA to change user ID
- Allow ranges for sACN and action that sets level by address to Show Control Event List
- Add Hide Master/Cells to Flexi and post options in CIA
- Add support for multi-cell fixtures
- Add Channel Bounce to step/absolute effects
| 2.6.4 |
Jan 11, 2018 |
- Support for Enhanced Hardware
| 2.6.3 |
Dec 8, 2017 |
- Network Interface Delay
- Snapshot Softkey For Updating
- Bug Fixes
| 2.6.2 |
Oct 19, 2017 |
| 2.6.1 |
Aug 31, 2017 |
- Support for Ion Xe
- Support for Eos Standard Fader Wings
- Bug Fixes
2.6.0
July 27, 2017 |
- Add [Reset Columns] to tab config menu for all tabs
- Quick-Access popup tools
- [Silent mode] button to Time code lists to countdown time, but not fire events
- [Sub 1 CopyTo Sub 2 Attrs Only] to only copy subs attributes, not levels or effects
- Fader Config: Manual Time master
- 3 decimal places in target numbers that allow decimals
- Changes to Subs With Effects
- Expand collapse button to last column of CIA parameter table
- Setup option to disable Element help message prompts above command line
- Blind Spreadsheet shows all parameters by default
- DirSel Dbl Click Option Added for Element
- Use Shift + Label as a shortcut to get to Cue Notes
- An option to the Macro editor to exclude execution of the associated macro from being learned by Time Code
- The ability to save logs from the main Eos app, without having to exit to the shell
- [Chan 1 CopyTo Chan 2 From_Absolute] to copy chan 1's absolute value to chan 2
- Show Control : Midi Notes
- Row in "About Address" shows sACN input value
- A Cue List in Solo Mode should be exempt from external show control triggers
- Scene targets on custom direct selects
- Current value added to Show control list display's sACN input events
- Enhancing Element Controls
- The use of any sACN universe (1-63,999)
- Hiding Scene Breaks in PSD config menu
- Fader Config: Macro X option for custom fader buttons
- Priority Marking
- Turn relays on and off via a macro
- Open virtual keyboard within patch fixture search
- "About +" Display Toggles
- New Query Conditions
- Snapshots: Selective Snapshot Interface
- csv Import
- About IFCB Palettes
- User Defined Monitors
- Label column in blind spreadsheet
- Support for 3rd party MIDI over USB on Windows 7 Consoles and ETCnomad.
- PC Keyboard should have a drop-down box to select language
- ETC changed our policy for output upgrades. Rather than incremental 1K, 2K or 4K upgrades above base output, we will offer two levels only. The base console and an unlocked version. For a breakdown of the new minimum and maximum output counts, reference the datasheet linked in the cell to the left.
| 2.5.2 |
Apr 4, 2017 |
- Previous versions 2.1.+ had an issue where quick, channel patched fader movements can sometimes be dropped, particularly in Element in channel mode. The issue was resolved in this version and it is highly recommended to update.
- Bug Fixes
| 2.5.1 |
Feb 21, 2017 |
- Bug Fixes
- Fader Unmap on Delete Option
- Clear Filter Controls in Fader Configuration
- Syntax Modifications
2.5.0
Dec 21, 2016 |
- Support for Gio @ 5
- New Direct Select Controls
- Graphical Shutter Controls
- Filtering on Playbacks
- IFCB/Preset Lists on Faders
- Fanning Multiple Targets in Blind
- Recording Cue Lists directly via [Load]
- Channel Level Release
- Solo Functions
- MIDI Note Input
- Support for Gadget II and High-Speed IO
| 2.4.1 |
Sept 29, 2016 |
- Element Only: After a deep clear, sub bump buttons do nothing until next [File new] or load a showfile.
- Bug Fixes
- Increase of the number of available macros [Escape] + [Load]
- Support for macOS Sierra
2.4.0
Aug 4, 2016 |
- Presets and IFCB Palettes on Faders
- Fader button and slider config
- 10 priority states
- 10 priority background states
- Back from first and go from last behavior
- Discrete playback setting
- Increase fader pages from 30 to 100
- Add Release and Off times to setup
- Option to include park buffer on a show load
- sACN input
- Scene Breaks
- Cue Notes
- Live/Blind and PSD config
- Page the PSD without putting focus on it
- Tab labels
- Documentation tab
- Preview mode
- More modes for specific parameters
- ML controls changes
- Shutter controls changes
- Cue List and Sub List changes
- Macro color ID
- Call macros on specific user or device
| 2.3.3 |
Jan 19, 2016 |
- Modified channel selection behavior from soft controls
- Emergency Mark options for “Mark Earliest M Cue” behavior
- Optional Step times in Absolute effects
- Optional Parameter settings in Absolute effects
- sACN universe expansion to 999 universes
- Added a fader object to Magic Sheets
- Installer Archive
| 2.3.2 |
Oct 29, 2015 |
- New Flexi State called Flexi in Use, which includes channels that are marked
- Direct Select Color Coding
- Update a single monitor snapshot
- Save and restore ECU settings
- Workspace access from the command line
- Show Control indicators in the PSD
- Support library updates on Mac
- Shift + Highlight to append to the command line
- Go to Cue Out has no impact on a cue list that is in Solo mode
- Paging the effect list
- Add symbols to virtual keyboard
- sACN and Artnet offset display in patch
- Color Picker Gel swatches in gel or tungsten display
- Adds the ability to install Eos software and Fixture Library Updates directly from .zip files, without having to unzip first
| 2.3.1 |
Oct 6, 2015 |
2.3.0
Jul 30, 2015 |
- Allow arrow keys to edit labels
- Add OSC Transmit/Receive
- Partial Channel Merge
- About Submaster
- Add Parameter Tiles to Element
- Query Effect
- Allow Size on Absolute/Step effects
- x25 DS changes
- Multiple Gadget Support
- Lightwright Import Changes
- Provide looping functions for Select Last
- Shift + Enter and Shift + At
- Add By Type Presets
- Change Hotkey mapping
- Add more control to behaviors that stop an Effect (Continuous Run)
- Add more control to restarting single shot Effects (Repeat on Go)
- Add Stop All flag for effects
- Add effects in Presets (non-referenced)
- Allow +, - or % of Background states for effects
- Extend Cue and Submaster effect overrides
- Add a Channels in Use function
- Add display controls for About
- Color coding the Browser Support
- Discrete time as percentage of Cue category time
- Add optional abstract color spaces
- Add Spectrum color controls
- Add Color tinting tools
- Add Color Path with live scrubbing tools
- Add controls to Gel Picker
- Improve color matches
- Add Text fields to patch and query
- Add Moving Light Assistant to Export menu
- Local RDM
2.3.0 Release Note
| 2.2.1 |
Nov 10, 2014 |
2.2.0
Jun 12, 2014 |
- Support of Nomad 256, 1024, 1536 and 2048
- Support of Nomad Puck 256, 1024, 1536 and 2028
- Fixed Tab Numbers
- Framed, user adjustable displays
- Multiple workspaces per display
- Single Monitor Snapshots
- User designation of where new tabs open
- New channel distribution tools for Offset
- Channel level effect overrides
- Default Preheat time
- Additions to About
- Macro editor changes
- Add snapshots to Element
- Windows 7 Ion, Element, Ion RPU, and the Net3 RVI
- Support for ETC Net3 Concert
| 2.1.2 |
Feb 28, 2014 |
| 2.1.1 |
Jan 21, 2014 |
| 2.1.0 |
Jun 10, 2013 |
- GUI and output performance optimizations
- BMP and tap rate for effects
- Tabs in Element
- Cue list index in Element
- CIA favorite in Element
- [Shift]+ Direct Select to post unterminated to the command line
- Magic Sheet enhancements
- Changes to Magic Sheet channel selection
- [Query] {Unpatched}
- Parameter allocation counter in About
- Increase channel count to 16,000 (not available in Element)
| 2.0.1 |
Jun 10, 2013 |
- Latching data and time
- Rem Dim at percentage of current value
- User -based Capture Latch
- Loading a cue with a temporary time
- Increase number of submasters to 999
- Partitions on cue lists
- Auto-block clean up
- Auto-block indicator in PSD
- Changes to Update defaults
- Cut cues via [Shift] + [Go/Back]
- Indication of unsaved show data
- Mirror mode selection from shortcuts
- Magic Sheets on Direct Selects
- [Recall From] [Park]
- Change to Swap in Patch
- Channel Subgroups
- Import Custom Gobo images
- Increased number of pixel maps to 40
- Patch by Channel in Virtual Media Server
- Addition of 2nd color picker in Virtual Media Server
- FDX dimmer feedback
2.0.0
Mar 13, 2013 |
- Support for Eos Ti
- Magic Sheets
- RDM functionality from Net3 Gateways
- CEM+ and CEM3 Dimmer feedback
- Swap and unpatch in the patch display
- Curves list in patch
- DMX output column added to Patch
- Revised “Interface” indications in patch
- In patch Element defaults to patch by channel
- Mouseless patching
- Library organization changes
- LD Flags Enable/Disable in patch
- Notification when output parameter limit has been reached
- Color Calibration for D40, D60 and S4 LED
- Add “inverted” to default curves
- Addition of Record Only to Element
- 10,000 channel numbering on Element (subject to 250/500 desk configuration)
- Flexi mode for direct selects
- Out of Sequence sync enable for secondary cue lists
- Shift + Clear to clear the command line
- Shift + Fader Page to page back by 1
- Recall From HTP
- Shift + Block to post Intensity Block for cues
- Partial show read of individual cues now correctly includes tracked levels
- Adjusting cue rate now adjusts cue duration
- Go to Cue Complete Go to Cue at a percentage of completion
- Sneak Counter in the PSD
- Add split times, delay and category times to Go to Cue syntax
- Split Channel/PSD tab option under Displays for all devices except Element
- Cues and subs can be loaded with or without Enter on the command line
- Shift + At to recall last channel/parameter selection with no value
- Setup option to hide/display mouse cursor
- Revised Artnet Support
- Dual NIC enabled on Gio
- Avab VLC file import
- Serial strings apply to specific users if so identified
| 1.9.12 |
Jul 17, 2012 |
- Added support for fader wings built after June 2012 (orange USB port)
| 1.9.11 |
May 9, 2012 |
- Source 4 LED support
- Message on Primary/Backup when master has changed
- Clients automatically reconnect to new master when master has changed
- On Gio, S1 - S6 are no longer hard keys
- Condition of Scroll lock enabled/disabled maintained on an external keyboard through a power cycle
- Ability to enable/disable Space Bar Go
- Partial Patch Import
- Pan + - n now valid syntax to remove “n” from current pan (or tilt) setting
- RFR enable/disable now macroable
- Addition of All M-Speed to parameter tiles
- Ability to overlap two discrete delay times
- Go to Cue Out removes all background values
- Addition of an improper shutdown message on next power up
| 1.9.10 |
Feb 29, 2012 |
- Support for Eos hardware change
| 1.9.9 |
Jan 26, 2012 |
- Support for Gio
- CEM3 Feedback and Configuration
- Scroller Calibration Column
- Added support for Ratified sACN
| 1.9.8 |
Nov 11, 2011 |
- Addition of the Shift function
- Syntax changes to maintained and combination button hits
- Released cue lists and submasters now release to the last owner
- Ability to set a cue list or submaster to disallow content from becoming the background state
- Ability to set a submaster action on the downfade to release to the background state or fade to minimum values
- Lowlight is now the value that selected but not specified channels will use when in highlight mode
- Addition of a rem dim value for highlight
- Temporary highlight value for intensity
- Ability to put a preset into the rem dim value(s)
- Reordering of the browser
- Ability to dim the littlites from software.
- Addition of a favorite button to the CIA
- Startup and Shutdown macros
- 99,999 channel count (still 10,000 total channels)
- Reorder command in group list index
- Go to Cue Out on a list basis
- Go to Cue Home to reset to the first cue of the specified list
- Default Mark Time
- Revisions to scroller/wheel editor in patch
| 1.9.6 |
Jan 27, 2011 |
| 1.9.5 |
Jan 13, 2011 |
- Virtual Media Server (pixel mapping)
- Shielded Submasters
- GM Exempt Channels
- Dynamic PSD countdown
- Channel level indicator for non-dim
- Channel Intensity flash on/flash off using Highlight + Full and Highlight + Out
- Use of the color and gel picker on “non-standard” LED fixtures (RGBA, RGBW, etc)
- Dual set of direct selects when opened on a tab
- Flexi-Encoder state option
- Channel/Address check mode for the RFR
- Changes to the handling of dual scroller fixtures
- Delay effects in cues
- Cue release to last active source
- Macro flag to force macros to run in the foreground (on the command line) or background
- The return of Time / for setting downfade times
- Manual Master Cue List
- Changes to update thru and the addition of update +
- Changes to mark
- [Enable] and [Disable] flags added to any macro changing a setup option
- Additions to the .pdf printout
- Setup tools for changing the resolution of trackballs.
- Encoders always disabled in blind until a paging button is pressed.
- Snap facility added to specified parameters.
- Expansion of the Serial I/O functionality.
- Congo and NT show file import.
1.9.5 Release Note
| 1.9.2 |
Dec 2, 2010 |
| 1.9.1 |
Aug 25, 2010 |
| 1.9.0 |
Apr 1, 2010 |
- Multiple Intensity effects on a single channel
- Live/Dark move indicators on PSD
- Scroll lock no longer required to engage hotkeys
- Content of NPs on I-Master subs can be released by pressing the bump button again.
- Remote Device Start up/Shut Down
- Remote software install
- Changes to Update
- By Type Palettes
- Locked Palettes
- Absolute Palettes
- Introduced Tabs on Ion
- Introduced Query on Ion
- Introduced Snapshots on Ion
- Introduced Channel Mode for fader wings
| 1.8.2 |
Feb 3, 2010 |
| 1.8.1 |
Jan 18, 2010 |
| 1.8.0 |
Oct 15, 2009 |
- Mirror mode
- Fan
- Introduces the ability for an RVI or PC to connect to an Element system in client or mirror mode.
| 1.7.0 |
Jul 30, 2009 |
- Effects stored and controlled by submasters
- Multiple external USB connections for fader wings
- Color Format Controls to toggle between native and HS color settings
- Display of frame tables by Frame number
- Setting Gel matches from the command line
- Zoomable displays
- External track ball support for mouse operations and pan/tilt controls
- Improved support for multi-intensity channels
- Latching fader controls (Ion)
- File Manager in the shell
- Support for the iRFR application
- Lamp controls are added to the fixture editor
- Disabling Automarks automatically creates referenced marks
- 1 new format for the PSD, enabling display of two cue lists, both or either of which can be locked
- Dimmer feedback from Sensor + systems equipped with AF modules
- RDM configuration and monitoring
1.6.0
(Element Only)
Jul 9, 2009
| 1.4.5 |
Mar 23, 2009 |
| 1.4.4 |
Jan 29, 2009 |
- Bug Fixes
- Adds support of networked RFR
| 1.4.3 |
Dec 5, 2008 |
| 1.4.2 |
Oct 2, 2008 |
- Ion Remote Processor Unit (RPU) support
- Artnet and Avab UDP Support
- I/O Gateway Support
- Real Time Clock (RTC) Programming
- Default 1 to 1 Channel to Submaster Mapping for Ion
- Revisions to the “Off” function
- Replace Function Added to Patch
- Record Rem Dim
- User Level Undo
- Removed Restrictions on Device Connections
- Update Library Feature Added
- Master Fader collected for Rate control by default
- [Clear] + [Tab] closes all open tabs (Eos only)
- [Record Target] [n] [thru] [Enter]
- Range channel selection for Lamp Controls
- Copy to and Recall from Live
- [Trace] [Trace] to add previously inactive lights to an update command
- Channel to Channel Recall From
- Marked to and Mark from added to Channel About
| 1.4.1 |
Jun 20, 2008 |
| 1.4.0 |
May 28, 2008 |
- 1x20 Universal Fader Wing Support (Ion only)
- Offline for Mac
- Universal Fader Wing Support of Playbacks
- 12,000 outputs available
- 200 active playback faders and 999 cue lists
- 10,000 channels
- Submaster changes
- Definition of fader as proportional or intensity master
- Normalized shutter controls
- User programmable Home
- Highlight and Lowlight changes
- Flexichannel changes
- Assert from the command line
- Automatic channel reselection following an record action
- About Channel revisions
- User definable Remainder Dim level
- Channel level Go to Cue operations
- Select Active and Select Manual functions (Ion)
- [Trace] [Trace] will now go as far back in the cue list as possible
- New Print file options
- Add setting to preserve the Blind cue
- Ability to copy a range of cues to a range of submasters
- Remove fixture parameter dependencies
- Pressing Live or Blind while already in those modes will re-sync the selected cue.
- Convert references to absolute data when deleting a palette or preset.
- Master/Primary text changes
- Resolution settings for external monitors
- Capture latch and update mode are saved with show file
- Macro Wait for Input and Resume
- Block is now an editing function only
| 1.3.1 |
Feb 21, 2008 |
- 2x20 Universal Fader Wing Support
- Loading Cue Lists
- Changes to Offset
- Improvements to Partitioned Control Editing
- Block DMX Ranges
- Front Panel Macros (Eos Only)
- Improved Summary Displays
- Improved Playback Displays
- Virtual Encoder Controls
| 1.3.0 |
Dec 6, 2007 |
- Ion Support
- Partitioned Channel Control
- Channel Level Delete commands
- Patch [At] [Next] commands
- Move to in Patch
- Cue Level Timing Changes
- Utility Reports
- Preheat
- Selective Partial Show Read
- Offline Visualization Support
| 1.2.1 |
Oct 25, 2007 |
| 1.2.0 |
Aug 23, 2007 |
- Support for the Net3 Radio Focus Remote
- Support for the Universal 2 x 10 Fader Wings
- Snapshots
- Curves
- Undo
- Fixture Editor
- Update Dialogue with new update options
- Playback Status Display sychronized to lie and blind operations
- Revised library and encoder mapping
- Revisions to dependent parameter controls
- German Translation
1.1.0
Apr 26, 2007
- Synchronized Backup
- New displays formats for playback status and live/blind table displays
- MIDI Input via Net3 Show Control Gateway
- Queries
- Direct selects anchored by whole number
- Display of palettes and presets by label or by number
- Configuration of submasters directly from command line
- Partial show reads
- Dimmer-Doubling™ support
| 1.0.0 |
Nov 16, 2006 |
- Initial release of software
