Close Hog 4 PC
Hog 4 PC can be a little tricky to close to newer users. There are several ways to close Hog 4 PC:
Right Click (Hog 4 PC only) (Best/Proper Route)
Task Manager (Hog 4 PC Only)
Fix/Solution:
1. Right Click (Hog 4 PC only) (Best/Proper Route)
Right-click anywhere in the interface
Select "Quit"
2. Soft Key
Press [SETUP]
QWERTY shortcut [S]
Select (Quit) soft key to close the application
Select (Log Off) to go to the start screen
3. Launched Processes
Open Launched Processes
Press [SETUP]
QWERTY shortcut [S]
Select (Processes)
Shortcut [PIG] & [OPEN] & [BACKSPACE]
QWERTY shortcut [CONTROL] & [O] & [BACKSPACE]
Select (Quit) to close the application
4. Power Down
Restart computer/console by physically flipping the power switch found in the back of device
5. Task Manager (Hog 4 PC Only)
NOTE: This route is highly discouraged, and should only be used if the program has crashed or is not responding. It is generally best to restart the computer to ensure all tasks have shut down.
NOTE: All processes need to be fully shut down before restarting Hog 4 PC, Starting Hog 4 PC with an old process still running will cause multiple issues.
Open Task Manager
[CONTROL] & [SHIFT] & [ESCAPE]
[CONTROL] & [ALT] & [DELETE] Select "Task Manager"
[WINDOWS KEY] Type: "Task Manager"
Find the folder for "Desktop"
Right-click and end task
Find the folder for "Launcher"
NOTE: If tasks are not grouped into a folder, then each one will need to be manually ended.
Critical
DP 8000
Launcher
Server
Visualizer
Note: This task might not be enabled based on your settings, off by default
Desktop
